TwinTurbo.NET: Nissan 300ZX forum - Tps voltage
Tps voltage
Bigmatthew86
on October 05, 2018 at 3:51 PM
I was attempting to adjust my tps today & couldn't quite get in in spec. I'm at .46 closed but that is only 3.84 wot. Adjusting it to .5 gets me to 3.9 but it doesn't shift as well. How important is it to be 4-5 volts when wot?
Tps voltage -
Bigmatthew86
15:51:38 10/05/18
I'd set it at about 0.46 closed with the car running. Then,
MixManMash
23:45:05 10/05/18
Re: I'd set it at about 0.46 closed with the car running. Then,
Bigmatthew86
08:12:36 10/06/18
Where did you ground the meter for checking the voltage?
jzack
12:33:22 10/06/18
This. (n/m)
MixManMash
13:46:01 10/06/18
The FSM says approximately 4.0V on WOT.
MixManMash
13:51:58 10/06/18
Specs and how to adjust TPS here>>>>>>>>>>>>>>
ZUL8TR
13:37:03 10/15/18
